It is currently Sun Oct 26, 2025 9:21 pm
PostPosted: Sun Apr 13, 2008 6:23 am
i've read people here talking about eibach springs?
does eibach makes lowering springs for the 3G? it says that it has only for the eclipse 2wd 89 model. my question is would this also fits our mirage?
PostPosted: Sun Apr 13, 2008 8:40 am
makes your car unusably low IMO. Eibach did (maybe still do) make springs for our cars in Europe though...
LC '01 Accent GSI - Silver
PostPosted: Sun Apr 13, 2008 9:52 am
Eibach Pro-kit springs or Eibach Sportline springs made for a 1G FWD or 1G AWD will bolt right up to a 3G CSM. The Eibach AWD springs are a bit stiffer than the springs made for a FWD. Also, the Sportline springs drop the car a little bit more than the Pro-kit springs do. I believe the Pro-kit springs lowering the car around 1.25" and the Sportline springs lower the car around 2". On a side note, I would recommend upgraded your struts to some KYBs at the same time or soon after switching to some Eibach springs. Just for a smoother and more balanced ride.
PostPosted: Sun Apr 13, 2008 5:27 pm
what about a setup of koni struts and eibach springs would the pair be a perfect match.
what would be a tolerable drop? or is it better to maintain the stock height of the car making those lowering springs useless
PostPosted: Sun Apr 13, 2008 8:17 pm
Buy ground control coilovers drop the car 1.5" and have a blast I've had this setup for years..
Buy ground control coilovers/konis drop the car 1.5" and have a blast I've had this setup for years..
PostPosted: Mon Apr 14, 2008 7:47 am
do you mean koni's ground control? where can I buy those?
PostPosted: Mon Apr 14, 2008 8:13 pm
www.ground-control.com
www.koni-na.com
PostPosted: Mon Apr 14, 2008 8:32 pm
So i guess the 93-96 application will work for my 91? Just want to make sure.
PostPosted: Mon Apr 14, 2008 9:17 pm
http://forum.4g61t.org/viewtopic.php?t=3137
AWD DSM kit
PostPosted: Sun Apr 20, 2008 1:56 pm
I just cut 1.5 coils off each spring... made for a good height and actually made the car more stable. It used to feel real light a floaty over bumps on the highway but now it feels solid.
Berz out.
PostPosted: Sun Apr 20, 2008 5:52 pm
B and G makes lowering springs for a 3rd gen, I have them on my car, they lowered the car the perfect amount IMO, im happy with them
PostPosted: Tue Apr 22, 2008 5:53 am
Was looking on ebay and I found these. I would how these would ride!!!
http://cgi.ebay.com/ebaymotors/ws/eBayI ... =p3907.m32
PostPosted: Tue Apr 22, 2008 8:23 am
You'd need 89-92 references for the parts in question, as those are probably the CC Lancer fitment of 93ish + model years.
PostPosted: Tue Apr 22, 2008 10:13 am
This is a dumb question but couldn't you put the stock suspension front a 1g talon fwd into a csm and that would lower it some? Since lowering springs for them lower it more for these, it could only make sense.
