It is currently Mon Jun 03, 2024 6:41 pm
PostPosted: Wed Dec 03, 2014 9:06 pm
so correct me if im wrong, im going to be swapping a 7 bolt 4g64 into my 4g sedan and a 5 speed 1G auto trans into it for daily driver purposes.
I would need:
-7 bolt 4g64 block
-6 bolt 4g63 head or 7 bolt?
-4g64 timing belt and exhaust cam gear
-4g64 Head Gasket
-4g63t ECU that is from an auto car
-2G MAF or or 2G MAP sensor and N/A intake from 4g64
-4g63 450cc injectors or 4g64 N/A injectors
I have an authentic Evo 3 ECU and Evo 3 engine wiring harness that I would like to use because the intercooler sprayer hookups and fender marker lights but not sure if that would work on this, looking to build this so my girl can drive it around since my 4g15 I have in it now is about to die and has no power and a 3 speed trans. Any help is greatly appreciated because im trying to keep this a budget build. I will eventually be swapping forged internals and lowering compression for a turbo setup and Manual trans but thats down the road
91 Talon TSi AWD- SOLD
91 Mirage 4dr 4G63T -Daily
facebook.com/modicausmc
PostPosted: Wed Dec 10, 2014 6:43 am
First of all, 1g Auto Transmissions are 3 speed not 5 speed
Second for a 4g Mirage don't you need a 2g transmission type?
