| Mitsubishi Axle lengths http://4g61t.org/forum/viewtopic.php?f=2&t=6726 |
| Author: | Berserko [ Sun Dec 21, 2003 9:23 am ] |
| Post subject: | Mitsubishi Axle lengths |
This table shows the lengths of axles that mitsubishis use may make life easier at the wreck if you know what fits where. Application Inner Joint Outer Joint Length in. (mm) Eclipse 2WD 1.8L Left ................ TJ .......... BJ ......... 27.9 (709) Right ............... TJ .......... BJ ......... 14.5 (368) 2.0L (A/T Turbo) Left ................ TJ .......... BJ ......... 27.6 (702) Right ............... TJ .......... BJ ......... 14.5 (368) 2.0L (All Others) Left ................ TJ .......... BJ ......... 27.8 (706) Right ............... TJ .......... BJ ......... 14.4 (366) 4WD (A/T) Left ................. TJ .......... BJ ......... 14.4 (366) Right ................ TJ .......... BJ ......... 14.6 (371) 4WD (M/T) Left ................. TJ .......... BJ ......... 14.5 (368) Right ................ TJ .......... BJ ......... 14.5 (368) Galant 2WD SOHC Left ................ TJ .......... RJ ......... 27.9 (709) Right ............... TJ .......... RJ ......... 14.5 (368) DOHC Left ................ TJ .......... BJ ......... 27.8 (706) Right ............... TJ .......... BJ ......... 14.4 (366) 4WD A/T Left ................ TJ .......... BJ ......... 14.4 (366) Right ............... TJ .......... BJ ......... 14.6 (371) M/T Left ................ TJ .......... BJ ......... 14.5 (368) Right ............... TJ .......... BJ ......... 14.5 (368) Mirage 1.5L Left ................. TJ ....... BJ or RJ ...... 27.4 (696) Right ................ TJ ....... BJ or RJ ...... 14.5 (368) 1.6L A/T Left ............... TJ .......... BJ ......... 27.2 (691) Right .............. TJ .......... BJ ......... 14.3 (363) M/T Left ............... TJ .......... BJ ......... 27.2 (691) Right ............. DOJ .......... BJ ......... 14.1 (358) 3000GT SOHC (A/T) Left ................. TJ .......... BJ ......... 16.5 (419) Right ................ TJ .......... BJ ......... 15.5 (394) SOHC (M/T) Left ................. TJ .......... BJ ......... 16.5 (419) Right ................ TJ .......... BJ ......... 16.0 (407) DOHC (A/T) Left ................. TJ .......... BJ ......... 16.4 (417) Right ................ TJ .......... BJ ......... 15.5 (394) DOHC (M/T) Left ................. TJ .......... BJ ......... 16.4 (417) Right ................ TJ .......... BJ ......... 15.9 (405) 4WD Left ................. TJ .......... BJ ......... 16.5 (419) Right ................ TJ .......... BJ ......... 15.4 (391) (1) - Right indicates passenger's side, and left indicates driver's side. (2) - Type of CV joint used are identified by letters as follows: BJ - Birfield Joint, DOJ - Double Offset Joint, RJ - Rzeppa Joint, and TJ - Tripod Joint. |
