It is currently Wed May 27, 2020 4:11 am
 Post subject: 14b/16G on 4g61
Here is a list of parts needed to install a 14b or 16G on a 4g61 engine.
[b:570a00fn]Parts Needed[/b:570a00fn]
1G or 2G exhaust manifold, or port your 4G61 (not recommended)
1G or 2G o2 housing
MD140476 new waterpipes (these are needed to fit turbo to car)
MF650114 x2 two waterpipe banjo fittings/eyebolts
MF660065 x4 four water copper crush washers
MD117764 gasket between o2 housing and turbo
you also need the 12mm banjo for the oil line into the turbo
[b:570a00fn]Other parts[/b:570a00fn]
Not necessary but *highly* recommended from a turbo builder's standpoint:
New oil feed line MD140394
New oil return line MD150523
MD311230 new o2 sensor
New gaskets and copper crush washers.
*Info provided by Ben K.
**More info provided by Cyborg
