| Slicks? http://4g61t.org/forum/viewtopic.php?f=18&t=32675 |
| Author: | UnderPSI [ Wed May 12, 2010 10:18 pm ] |
| Post subject: | Slicks? |
I can get an awesome deal on a set of 22.00/8.0-13, and I was if anybody had a experience with them? Also does anyone have any cheap wheel suggestion to go with them? I really cant pass this deal up(only 5 passes on em for 100) and have been looking for slicks. |
| Author: | Crackerman [ Wed May 12, 2010 11:15 pm ] |
| Post subject: | Re: Slicks? |
under 400 hp, go for it. diamond racing is about as cheap as you can get in a 13x8 wheel. more than 400 hp and with a f5m33 trans, go with bigger tires, like a 24x8x15 |
| Author: | Enter [ Thu May 13, 2010 8:26 am ] |
I have mine mounted on volvo spare tire steelies. Full size rim |
| Author: | CaptainTonus [ Thu May 13, 2010 10:01 am ] |
Quote: I have mine mounted on volvo spare tire steelies. Full size rim
Those wheels have the right bolt pattern?
| Author: | Enter [ Thu May 13, 2010 10:04 am ] |
Quote: Quote: I have mine mounted on volvo spare tire steelies. Full size rim
Those wheels have the right bolt pattern? |
| Author: | UnderPSI [ Thu May 13, 2010 3:23 pm ] |
Quote: under 400 hp, go for it.
Yea Im running a f5m33 and im pretty sure the car puts down close to 400 the way it sits, as for that I am worried this going shortin my gear ratio up badly. Last time I was at the track 3rd gear was all but used up in the 1/8. The cars rev limiter has been raised from stock to 7750 rpms but I dont think thats gonna stretch the gears much.
| Author: | Crackerman [ Fri May 14, 2010 1:53 am ] |
with 22x8x15's i ran 99.4 mph in the 1/8th in 3rd gear at right around 7700-7800. i have since moved up to a 24.5x8.5x15 slick and would now like to trap the same rpm in 3rd with the taller tire. if you can trap 99+, go bigger, if not, stay small. |
| Author: | Codeofdastreets [ Fri Apr 06, 2012 1:43 am ] |
Y do you guy use a 15?? I"d use a 24.5/9.0/13 tire on a spunwerk rim |
| Author: | Coltsfan [ Fri Apr 06, 2012 10:55 am ] |
I know a good reason to run a 15" wheel.
