It is currently Wed May 22, 2024 12:49 pm
PostPosted: Thu Feb 27, 2003 11:55 am
Would this be a good thing? since the amount of power the 2.0 liter is doing and the little frame of the car i think it migh get into a toe out angle under hard acceleration.
Any body tried this on their car for drag race?? underdog?
PostPosted: Sun Mar 02, 2003 2:25 am
actually, here goes
if you toe out slightly it will create a better contact patch, as the tires toe in under hard acceleration, rubber gives a little, and tires rotate forward on the imaginary pivot point located by the control arm bushings, as the tires have to pull the car forward.
if you toe in, it will make it worse,
toe out will screw up your high end stability, whigh is bad
so , i would reccomed just aligning it to stock specs
PostPosted: Sat Jun 07, 2003 11:35 am
my car is set toe out.... kinda like this on jack stands \ / when the car is on the ground you really cant tell, but this def helped in initial traction... and YES some high end stability is lost. Hopefully i can pick up a quaife soon.
1989 Turbo Mirage.....
4G63 no Balance shafts, 20G turbo, Front mount, Tial WG dumped, O2 Elimitnator, Full 3" SS Exhaust, VPC, SAFC, HKS BOV, KYB GR2 Struts, Springs, best of 12.4 @120MPH!!!
PostPosted: Wed Aug 20, 2003 12:43 am
I had to add a brace between the lower front monting points for the control arm because the crossmenber flexs so bad, but it flexed inwards not out, I did end up going with some toe out to help reduce the effects even after the urathane bushings and the lower brace.
I could see the flex with the naked eye and on the videos of my runs. But I was running 1.55ish 60 ft times with 28x10.5x15 slicks.
Tom
1993 Dodge Colt 4dr 4G63t
9.686 @ 143.47 mph
