Evo I hits up the 1/4 mile. Results inside. http://4g61t.org/forum/viewtopic.php?f=18&t=30672 |
Author: | 93'TSIColt [ Mon Sep 14, 2009 3:47 pm ] |
Post subject: | Evo I hits up the 1/4 mile. Results inside. |
Evo The evo finished up with a best of 14.1 @ 97 MPH w/ 1.9 60'. I beilive if i launched a bit better i could have netted a 13.9 @ 99-100 MPH. This was TOTALLY stock (besides the ARC airbox with a crappy paper air filter)... some very minor boost leaks, stock exhuast, Car seemed to pull hard tho, could use more top end power... but i guess that is what to expect from stock exhuast and the smaller ports in the 7 bolt head. A full 3" inch exhuast should really waken it up and i bet mid 13's easy on stock boost with just exhuast. Thats the first time ever with a sub 2.0 60' ever for me!! I actually expected to run more in the mid 14's... maybe even high 14's. Short gears and a long first gear prevailed. Weighed the evo as well on the scale. without the 50 lbs of junk in the trunk (tools,water,etc) it weighed in at 2760 lbs without me in it. Not bad for a cast iron blocked 4g63t with AWD and being 4 door car! This car also put down 172 AWHP on a mustang dyno a couple weeks earlier |
Author: | MattGSR [ Mon Sep 14, 2009 4:09 pm ] |
Post subject: | Re: Evo I hits up the 1/4 mile. Results inside. |
hey thats not bad at all, the evo1 is lightweight wow only 2700+. I bet you could pick up 2-3mph if you let the exhaust breath a little. My evo8 weighs about 3300lbs and i could only get 13.8 in stock form. |
Author: | pimpy rider [ Mon Sep 14, 2009 8:48 pm ] |
How much boost do those things run stock? |
Author: | 93'TSIColt [ Tue Sep 15, 2009 9:47 am ] |
around 13 psi. |
