It is currently Sun Jun 16, 2024 4:17 am
 Post subject: anyone auto-xing a 4dr?
PostPosted: Mon Jul 03, 2006 11:04 pm
im just curious if anyone is using a four door i would like to see what spring rates there using. i was thinking like 350lbs in the front and 400's maybe 450's in the rear....what do you think.... i like having a low car but hate rubhbing cause my springs are to soft. so far i swaped in awd rear kyb's and factory awd springs but still not stiff enough. any insight would aprecited tnx
-kevin
>IezarI<
specs:
94 eprom
wb 255 with re-wire
turbo 2.5 ex
gm maf w/ translator
2.5 fmic and pipes
rc 550's
n/a 60mm tb
2g t25(15 psi)
PostPosted: Tue Jul 04, 2006 4:57 pm
I have an elantra (same frame as a C60 CSM) I would say 400 would be my top value if you ever want to run on the streets and I would keep the values the same front and rear I found I get understeer if the values aren't matched...
LC '01 Accent GSI - Silver
