widest rim to fit on a colt? http://4g61t.org/forum/viewtopic.php?f=18&t=13297 |
Page 1 of 2 |
Author: | chrisgvr4 [ Thu Mar 24, 2005 7:22 pm ] |
Post subject: | widest rim to fit on a colt? |
What's the widest rim that anyone has fit on a colt and been able to tuck the tires under the fenders? I'll roll the fenders like hell if I have to but I don't want to do flares. I"m not worried about max tire width as I'm going road racing so there is no point on shoving a huge tire on too narrow a rim as it doesn't perform any better. Any hope of 8"? wider? narrower? |
Author: | dragstr4g61t [ Fri Mar 25, 2005 2:11 pm ] |
Post subject: | |
If your planning on competing, the widest most classes will let you run is 7" and that is pretty wide on a CSM. You may get an 15x8 put its gonna be close if you lower the car more than an inch. |
Author: | chrisgvr4 [ Fri Mar 25, 2005 4:03 pm ] |
Post subject: | |
If I compete I'm looking at ITE anyway. Car isn't classed in ITA, ITB, ITC or ITS... ![]() For AutoX i'll be street mod it sounds like. Car will definitely be lowered a good amount. I can fit some wilwoods under 15x7s so that may be my size of choice although it sure would be nice be able to go to 8.5". |
Author: | dsmracer [ Sat Mar 26, 2005 12:52 am ] |
Post subject: | |
I know ITE is a free for all class of sorts, but you'll still have to conform to the IT specs which will be 15x7" max. |
Author: | chrisgvr4 [ Sat Mar 26, 2005 11:37 am ] |
Post subject: | |
Quote: I know ITE is a free for all class of sorts, but you'll still have to conform to the IT specs which will be 15x7" max.
I don't think that's true, at least in the rocky mountain region? My friend's 3si just got teched for ITE and is running 18x9s? If ITE is a free for all, then what rules do you have to follow and what can you break ya know?
Author: | MR HYDE [ Mon Mar 28, 2005 6:15 pm ] |
Post subject: | |
7 inch is the widest with a 42mm offset |
Author: | Dende [ Mon Mar 28, 2005 6:34 pm ] |
Post subject: | |
sort of on topic i have a set of 15x7 rims what tire size would you recommend. they came with 195's would anything wider fit or would it not be worth it(stock ride height on a 4g61t) |
Author: | MR HYDE [ Mon Mar 28, 2005 6:55 pm ] |
Post subject: | |
Quote: sort of on topic i have a set of 15x7 rims what tire size would you recommend. they came with 195's would anything wider fit or would it not be worth it(stock ride height on a 4g61t)
205/55-15
Author: | netninja2001 [ Mon Mar 28, 2005 7:01 pm ] |
Post subject: | |
here's my 205/55-15 on lancer oz rally edition rims. front is lowered with dss coilovers and konis and rear is stock height (just remember the rear is higher in the first place) ![]() EDIT - oh yeah, it's not like that anymore, now it's all lowered ![]() |
Author: | IuSe2bTuRboCoLtGt [ Tue Apr 12, 2005 12:25 am ] |
Post subject: | |
Maybe a little late but I have 17x7.5 5zigen copses. They dont rub or anything. |
Author: | chrisgvr4 [ Tue Apr 12, 2005 9:26 am ] |
Post subject: | |
Quote: Maybe a little late but I have 17x7.5 5zigen copses. They dont rub or anything.
What offsets?
Author: | souk [ Tue Apr 12, 2005 2:04 pm ] |
Post subject: | |
Quote: 7 inch is the widest with a 42mm offset
anyone know if a +42 offset you could only put on, can you go any lower say with a 15inch rim with a +15 offset?
Author: | chrisgvr4 [ Wed Apr 13, 2005 3:29 pm ] |
Post subject: | |
I'll be playing with this more. I'm going to get some 15x7s but I want to get the offset right so that they are as close to the coilover (which i don't have yet) as possible and then I can tuck some 225 race rubber under a rolled fender with the car lowered....I hope |
Author: | IuSe2bTuRboCoLtGt [ Thu Apr 14, 2005 8:12 am ] |
Post subject: | |
Sorry man I don't know the offsets on these 5zigens. |
Author: | chrisgvr4 [ Thu Apr 14, 2005 9:40 am ] |
Post subject: | |
Quote: Sorry man I don't know the offsets on these 5zigens.
They will say on the wheel usually. It will be in the +35 to +40 range probably. How much space do you have to the strut and how far do they stickout past the fender?
