It is currently Tue May 14, 2024 12:53 am
PostPosted: Sun Mar 20, 2005 8:08 pm
OK I have a complete wiring harness out of a 92' TSI. I need to know which wires are needed and what ones are not. I will be using a simple push button start (no key). The car will have lights and blinkers on a totaly different harness.
One I do not need:
62 Purge control solenoid valve
53 EGR Control Solenoid Valve (90-93 CA only, 94 all)
65 Air conditioner relay
3 Turbo gauge
5 Power steering oil pressure switch
15 EGR temperature sensor (90-93 CA only, 94 all)
7 Air conditioner switch
11 ABS control unit (AWD, ABS only)
Do I need a MPI? Can I just have switches?
Adam
93'FD Touring non-seq
05'WRX
PostPosted: Mon Mar 21, 2005 2:42 am
What Stand alone are you running.
Corey
90 C50 4G63 Swapped-Drag car
92 Eagle Talon Tsi AWD
96 Mitsu Eclipse GS-T
www.ongreenperformance.com
PostPosted: Mon Mar 21, 2005 6:33 am
Its not a stand alone, it's a 92 TSI wiring harness and E-PROM ECU. I just want to simplify the whole thing.
Adam
05'WRX
PostPosted: Mon Mar 21, 2005 5:38 pm
One I do not need:
3 Turbo gauge
62- purge solenoid will throw a cel if unplugged, maybe put in a resistor?
53-EGR, just unplug it, or not use it at all... if the ecu was originally from CA, my guess is you'll have to desolder a jumper/resistor in the ecu...?
65- AC relay, in the garbage it goes
3- turbo gauge, see above? maybe?
5- PS switch, it's just a grounding switch, cut it and tape it, then forget about it...
15 - EGR, toss it in the bin, but ecu tweaking may be in order if from CA
7- toss
11 - sounds like a chassis harness part...
this should lead you in the right direction... i hope... :rolleyes:
phil
89 turbocan, 63t, GT30-13 (laaaag monster), tubular manifold by me, maf-Trans, phil-tuned ecu, bla bla bla.... you get the drift...
PostPosted: Tue Mar 22, 2005 2:04 am
Not really worth it on a factory ECU some of those things piggy back and you could really open up a can of worms.
Corey
PostPosted: Tue Mar 22, 2005 4:11 am
I don't have any of that shit plugged in on my 93 Colt, and error codes at all from the logger.
Darin
1986 GMC 3/4 Ton 4x4 Diesel (soon to be Greasel)
1993 Colt GL
PostPosted: Wed Mar 23, 2005 1:53 am
don't forget that you can use the boost gauge wire [at least with a tmo chip] to display other info [timing/o2 readings/etc]. you'd of course have to work in a stock dsm boost gauge somewhere, though.
are you asking so that you can eliminate the weight of the extra wires? that car better be pretty f'ing fast. g'luck.
1g smic, 2.5" turboback, 1g exhaust cam, abs intake, 13g turbo, mbc, vdo boost gauge, greddy egt
PostPosted: Wed Mar 23, 2005 7:44 am
yes Im trying to simplify things and lighten her up.
Adam
05'WRX
PostPosted: Thu Mar 31, 2005 12:20 am
I have all the electrical tape off and starting cutting out unneeded wires. The tape weighs quite a bit. I'm also going to reroute the wiring to clean her up.
PostPosted: Thu Apr 07, 2005 9:26 pm
Well I'm two weeks into this wiring harnes. I have a 92 TSi Engine harnes a 92 Summit 4g15 headlights/markers,rear tail lights and blinkers <-so I can still hazzard ppl AFTER i WOOP THEM:)
I had to take a few days brake thoe, I was going crazy. You guy would'nt belive how much unneeded wires are in these things.
Adam
05'WRX
PostPosted: Mon Apr 11, 2005 11:33 pm
Quick question do I need a reed switch? I dont have a speedo. Does the ECU use the signal for something?
Adam
05'WRX
PostPosted: Tue Apr 12, 2005 12:54 am
You don't have a speedo?
It's built into the gauge cluster
Factory ecu uses it for something with the idle
EMS also uses it to determine speed/speed related things
PostPosted: Thu Apr 14, 2005 12:24 pm
Nope it will have just a tach and other vital guages.
So the ECU needs a reed signal from somewhere right?
Adam
05'WRX
PostPosted: Thu Apr 14, 2005 6:15 pm
Interesting question. I don't think it "needs" it, I think it just plays some small part and won't be missed.
Witty Signature Goes Here!
