It is currently Mon Jun 03, 2024 7:34 pm
PostPosted: Sun Jun 15, 2003 11:40 pm
I was wondering if a suspension conversion form a galant or something of that sort would work? the car would handle much better. Just a thought that popped in my head...
PostPosted: Mon Jun 16, 2003 4:59 am
Anything can be done if you have the time and the money.... is it really feasible? not really...
PostPosted: Mon Jun 16, 2003 5:12 am
4g61t Delinquent
when i someday get a job im gonna have a friend of mine help me with making an IRS(Independent Rear Suspension) kit that even Beavis and Butthead could bolt up
I own a CSM.
PostPosted: Mon Jun 16, 2003 11:25 am
i was thinking taking it off an early civic (92)
PostPosted: Mon Jun 16, 2003 8:41 pm
BANNED FOR FRAUD
Mixing and matching parts from rivals? What do you think this is, Ford and Chevy?
Jason Veraldi
Scammer
PostPosted: Mon Jun 16, 2003 8:44 pm
i actually have a 96 civic... as a daily driver i would pikc the civic over the colt any day.
Honda's got some crazy engines. I also like the sound when the VTEC kicks in.
PostPosted: Tue Jun 17, 2003 1:28 am
4g61t Delinquent
why not a 2gen dsm
I own a CSM.
PostPosted: Tue Jun 17, 2003 4:56 pm
1595 cc's of fury
I don't think I would ever pick a civic...but thats just the honda hater in me. :evil: Though they are nice daily drivers...I just couldn't do it.
PostPosted: Fri Jun 27, 2003 2:43 am
4g61t Delinquent
ill second that!!!
On a serious note:
i was lying in my room thinking of a way to make our cars IRS...and i thought of using the bolt holes on the body for the "trailing arms" as a starting point. and work from there.....i was thinking of just eliminating the trailing arms and designing a "frame" that will use the trailing arm holes as a mounting location.....but i neet to locate another spot on where to make the other mounting spot. input on design is very welcome
Paul
I own a CSM.
PostPosted: Fri Jun 27, 2003 8:28 am
maybe some galant stuff.
PostPosted: Fri Jun 27, 2003 8:50 am
Why not just weld the 1G AWD rear suspension to the back. At that point you would be at least halfway finished with the AWD conversion.
PostPosted: Tue Jul 29, 2003 12:31 am
colt-r wrote: i actually have a 96 civic... as a daily driver i would pikc the civic over the colt any day.
tray-tore... :x :lol:
I have a 91 Talon AWD rear setup just wating for this :twisted:
http://community.webshots.com/photo/515 ... 9859AnvfQz
http://community.webshots.com/photo/515 ... 0449CMZKpY
the rear suspension is pretty self contained & if I remeber correctly it drops with just 4 bolts. I think if the flat areas where the AWD set up mounts to is reproduced on the rear floor of a CSM, & you'd probibly need a fuel cell in the trunk, it could work. I also have the drive shaft & X-fer case. :)
 Post subject: Even easier
PostPosted: Tue Jul 29, 2003 12:45 am
If anyone were really serious about starting this, I would be happy to work on some simple drawings to help out. It would actually be a lot easier to do as Hondahunter suggested and use the current trailing arms as starting points. Assuming it is a competition car, you would probably want a lot of suspension compresion induced negative camber (puts the tire flat after body roll) so the AWD setup is too limiting. I would probably start with GVR4 rear hubs (or DSM if you want the 5 lug thing) Additionally, with a few plate brackets, and some off the shelf parts this conversion is very feasable (NOTE: that I did not say reasonable!!!). It could easily be installed with the current fuel tank in place (well removed for installation). I dont remember if it could be bolt on, but I would assume it would be more of a weld on type of project.
cb
