It is currently Wed Jun 05, 2024 2:46 pm
 Post subject: Roll Cages.
PostPosted: Tue Jul 13, 2004 6:07 pm
http://www.ioportracing.com/Merchant2/m ... Code=AP680
Not bad pricing either
Geoff
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Tue Jul 13, 2004 6:18 pm
Yeah, I was wondering that too. :D
They actually have different types as well.
Geoff
89 2.0 Turbo Colt
PostPosted: Tue Jul 13, 2004 6:20 pm
Full-width roll bar hoop with two rear support braces, a diagonal cross brace and head restraint make up this roll bar.
Designed for Solo, Autocross and high-speed Time Trials
Meets SCCA and most race organization rules
Typically made of 1.750" × .120" mild steel - 2.00" × .120" ERW tubing is used for cars exceeding 3500 pounds (DOM tubing available as an option for an additional $35)
4-Point mounting with welded diagonal cross brace
Grade 5 mounting hardware and backup plates included
Available Options:
Removable (bolt-in) Cross Brace - allows easier access to the back seat area if the car is a dual-purpose street and race vehicle. If the Shoulder Harness Bar option is selected along with the Cross Brace, it will also be removable.
Shoulder Harness Bar - horizontal tube for harness mounting, extends the full width of the roll bar
Geoff
89 2.0 Turbo Colt
PostPosted: Tue Jul 13, 2004 6:55 pm
Very interesting. But what happened to kindly,old Dr. Jeykle? :o
PostPosted: Fri Jul 16, 2004 6:27 pm
Good link and they are about an hour from my house. I'll have to add that to the list for the street car.
Thanks,
Chris
 Post subject: Blah
PostPosted: Sat Jul 17, 2004 2:36 am
yes, good find. only thing that is see, is the install, that would suck. I made mine and installed it myself, in a fully guted car and it was a bitch. I feel bad for ANYONE that tries to install 1 in a non-stripped car.
MyRaceCarPics
MyWebSite
  • 2.0 dohc n/a swap
PostPosted: Sun Jul 18, 2004 1:48 am
Depends really on what your goal with the car is. If it's a street car/autocross car it'd definitely improve your safety level a little but also add a little weight. For any competition vehicle I wouldn't even consider it. It's your life that the cage is protecting. Personally my cage is similar in design to homologated FIA style cages for WRC rally cars. It has a few less bars but we are planning to add a few more. It's also a 7 point cage. My recommendation is to find a reputable local race car constructor and pay them to build it into the car. It's going to be able to be a tighter fit (safer) and your able to have some input.
Grant Hughes
Denver, CO
1984 Colt Turbo Rally Car 60K miles
1992 Subaru Legacy 200K miles
PostPosted: Wed Aug 11, 2004 8:39 pm
Having one built into your car is alot cheaper than that too.. I can get one done for $200 with whatever I want.. Only thing is.. you can't get it painted...unless your car is stripped inside and just have your whole interior painted aswell... But I'm cheap so I'de foam wrap it all up...
PostPosted: Thu Aug 12, 2004 2:51 pm
Dr Jeckyll a.k.a 4G61T engine got the boot long before I bought the car. All that remains is Mr Hyde The 2.0 engine that's in the car
He reminds me of his brutal and obnoxious presence everytime I try to get traction in 1-2 and 3rd gears :twisted:
Geoff
89 2.0 Turbo Colt
PostPosted: Fri Aug 13, 2004 5:37 pm
The materials alone for a good cage should run around $350-400. 1.5X.120 or 1.75X.095 is all we do for sizing. Any self respecting and good constructor should charge AT least $1000 in labor. If they're charging you less and not your brother or best friend, then you're probably the guinea pig for them. A Vermont Sports Car cage can cost around $5000. Again it depends on what your plans with the car are. Serious competition means serious cage. Weekend autocrosser that you want to make look cooler => less cage. Cheaping on a cage in a serious competition car is similar to putting stock brakes with Auto Zone pads on a 450 hp DSM.
Grant Hughes
Denver, CO
PostPosted: Fri Aug 13, 2004 6:21 pm
Yeah, that sounds about right. Ultimate Performance in Sterling, VA charges 200.00 per point when they build them.
Gary [the guy I bought my 2.0 Colt from] has a nice cage that was built by Xotic Motorsports. www.xoticmotorsports.com
Here's the direct URL to the Coltl Cage pics..... http://www.xoticmotorsports.com/gallery/ColtCage
Here's some nice pics :P
Geoff
89 2.0 Turbo Colt
PostPosted: Fri Aug 13, 2004 11:15 pm
Not a bad looking cage at all. I used to have pictures of mine online, but I don't have webspace right now.
Grant Hughes
Denver, CO
PostPosted: Sat Aug 14, 2004 12:25 am
BTW are the ones forsale in the first link.. in the first post.. for 4door or hatches??
Ayways shipping for me would end up being the cost of the cage itself... living in hawaii sucks! Yeah a friend does cages.. I haven't seen one that he's done yet.. but I would deff inspect before I buy... And I won't be doing serious competition.. as there is none here besides drag.. No roads to rally, and only autox stuff.. nothing major... I just want to feel a little bit safer in such a small colt HB....
PostPosted: Mon Apr 03, 2006 8:58 pm
check out chassisengineeringcom
I picked up my 6 point for 175$ and installed it myself.
