It is currently Sun Apr 28, 2024 12:56 am
 Post subject: Control arm bushings
Okay, I'm not positive on this, but......
The rear bushings on the front control arms on the turbo's are different then the bushings on the non-turbo's.
Let's assume that they are different because the turbos came with stiffer springs, bigger swaybar and a heavier engine. If this is why they changed them then the bushings are going to be stronger and stiffer then the ones that came on the non-turbos.
At any rate, the 1.6l bushings are about $30/piece from conicelli. It may be worth a shot for someone to try and see if these will bolt on.
The part numbers are: MB518969, MB518968
