It is currently Mon Oct 27, 2025 3:09 am
 Post subject: Should I do this?
PostPosted: Thu Apr 22, 2004 3:54 pm
I got a book that's titled "Turbocharge Anything." I was wonderin, should I even take the time to try and turbo my 4g15 and do a write up? I mean its something my dad and I have been thinking over for a long a$$ time and I've got other ideas for major power boost on the 4g15. But my main question is the turbo part, should I put the time into it?
I have never bought a car for more then 500 bucks.
First Car. '75 Toyota Celica GTS- $300
2nd- '89 Dodge Colt GL- $300
3rd- '90 Mitsubishi Mirage- $400
4th- '90 Toyota Pick Up- $500
5th- '93 Mitsubishi Eclipse- $100
PostPosted: Thu Apr 22, 2004 4:49 pm
you know man.. im in the same situation... wonderin if its gona blowup or anthing... but only one way to find out...and that is to do it!
PostPosted: Thu Apr 22, 2004 5:59 pm
rpw dont recommend it for some 4G15's, but running low boost you should be right
PostPosted: Thu Apr 22, 2004 6:08 pm
4g61t Delinquent
i wouldnt go over 6 lbs of boost. IMO youll blow something up
I own a CSM.
PostPosted: Thu Apr 22, 2004 8:57 pm
The 4g15 in my summit runs at 9.2:1 compression, I think that's a bit much for turbocharging isn't it?
PostPosted: Thu Apr 22, 2004 9:13 pm
IMO I think youd be better off tryin to make the 4g15 all motor than turbo.... boost would probably kill it but some nice cams... x1 pistons some porting and a few other things.... maybe even some nitrous and it would be a decent motor but thats just my 2 cents
www.4g61t.org, My Anti-Drug
Member #486
1992 plymoth colt 1.5 4spd soon to have 1.8 parts and much more
1991 Eagle Talon TSi AWD eibach springs, kyb shocks, front strut bar, white face gauges, and a system
PostPosted: Thu Apr 22, 2004 9:15 pm
i guess you just have to ask yourself what it is you want from your car and then ask if this route will get you what you want.
1992 Galant VR-4 810/1000
PostPosted: Thu Apr 22, 2004 9:17 pm
i'd go for it! i was thinking about turboing my 4g15 for a little extra kick in the future unless i get this new job and can afford 2 4g63t powered cars.
PostPosted: Thu Apr 22, 2004 10:38 pm
biuld and tune it right, it should take a decent bit
but unles you get some better internals, i dont ever see over 10psi
IMHO
RX-7 Fanatic
 Post subject: don't do it
PostPosted: Thu Apr 22, 2004 11:59 pm
That would be a waste of time and money. You would probably be disapointed with the results. Just do the swap.
PostPosted: Fri Apr 23, 2004 2:53 pm
Ricehunter turboed his 4G15. He ran IIRC less than 8 psi of boost. OTOH, some member of this board had 4G61T pistons in his 4G15. Maybe that's a way to use the strong turbo pistons in a little G15. :D
But w/ all those mods around, 110 HP are realistically for just NA mods.
Got rabies?
PostPosted: Fri Apr 23, 2004 3:20 pm
yeah, but I'm not the one that will be spending the money (well not compleatly), my dad and I are both wanting to do this and no matter what I'm still gettin the 4g63 out of the eclipse. I'm just going to do it. I don't think its going to be all that hard with an uncle around willing to let me use his shop. The only problem I see with this is the fact that i have to figure out the tunning so nothing goes wrong. My uncle knows how to get the compression right to run a turbo so I can have him do that part. I talked to him yesterday about this and he told me that the 4g15 is capable of running a turbo like the small sohc in them Hondas.
