It is currently Mon Oct 27, 2025 12:42 am
 Post subject: changing fuel pump...
PostPosted: Tue Apr 20, 2004 8:50 pm
hey guys i think my fuel pump went out today and i was thinking of replacing it with something better....... if im still running the 4g15 for a while what fuel pump should i choose sooner or later im probably going 4g64... just a thought....... would adding the 1.8 parts help the bigger fuel pump run betteR?
www.4g61t.org, My Anti-Drug
Member #486
1992 plymoth colt 1.5 4spd soon to have 1.8 parts and much more
1991 Eagle Talon TSi AWD eibach springs, kyb shocks, front strut bar, white face gauges, and a system
PostPosted: Tue Apr 20, 2004 9:10 pm
Second Gen Talon turbo....
PostPosted: Tue Apr 20, 2004 9:12 pm
about how much would one of those run me?
Member #486
PostPosted: Tue Apr 20, 2004 9:17 pm
also another question....... If i cut the key on shouldnt i hear the fuel pump buzz a little?
Member #486
PostPosted: Tue Apr 20, 2004 9:20 pm
I see them for like $25 on my local DSM forums all the time...
PostPosted: Tue Apr 20, 2004 9:22 pm
the 4g15 wont suffer from too much fuel being pumped?
Member #486
PostPosted: Tue Apr 20, 2004 9:59 pm
As long as the fuel pressure regulator is working good, you'll be fine.
PostPosted: Wed Apr 21, 2004 2:16 pm
Nope.The ECU controls the fuel pump via the MPI relay.
However, you can just hook +12V to the fuel pump test connector in the engine bay. It's the capped one near the wiper motor on the firewall, that has just one wire leading to it. IIRC the wire was yellow-red colored.
Got rabies?
PostPosted: Wed Apr 21, 2004 3:46 pm
Banned for being a dick
Below stereo infront of shifter, remove plastic section and you will uncover the MPI relay, small gold box with about 5 wires more or less running into it. That sucker stopped me from driving my rebuilt motor for about a week, yeah I thought my pump was bad. Well just goes to show little things can stop you from going anywhere. If you grab the box turn the key and you feel the box clicking, its done , dead and it needs to be replaced.
To see if your pump is working, disconnect the fuel line running to the fuel rail and put a small bucket under it, turn the key and see if fuel shoots out. Oh yeah this might not work if the MPI relay is dead, sorry just a thought.
PostPosted: Wed Apr 21, 2004 8:52 pm
well see my dad took the fuel line off the top of the fuel filter and cut the key on..... nothing...... what ya thinks causing this?
Member #486
PostPosted: Wed Apr 21, 2004 9:59 pm
well listen to this guys..... we turned the car over and we hear the fuel pump whine one time..... and when you go to click the key over to crank and dont hold the clutch down it clicks.... i put my hand under my ashtray to feel those relays but it felt like both of um clicked when i did that... cars gettin gas to the fuel filter now, when i turn the key over so whats this sound like when i start the car it hardly idles to 2 grand with the gas to the floor this cant be good i just got to find out whats doing this asap
Member #486
PostPosted: Wed Apr 21, 2004 10:31 pm
Could be your ECU... ECUI not powering the MPI relay and not turning on your fuel pump get those damn ECU caps replaced...
PostPosted: Thu Apr 22, 2004 7:10 am
well see my other ecus caps had leaked on the board when i took it out.... so i got another one and put it in there this didnt help any..... what else could it be.... like i said the fuel filter is getting gas when you turn the key over
Member #486
