You don't want a 2G motor all the sensors are different. And its a 7 bolt motor
You Also don't want a vista motor I heard their bell housings are different, and its a 7 bolt Motor
The 4g64 Sonata is the Motor of choice. and its also a 6 bolt.
so with the 4g64 will it be close to a 4g63t? does anyone know how much hp there is and which one has more low end power. I would think it is the non turbo but I have seen it theother way before. Can you put in the cams in a 4g63t motor? is there such thing as a 4g64t?
Will it be close to a 4g63 how? Power wise? It will produce approx 150 HP of N/A power stock more if you remove the balance shafts swap the head etc... and the 4g64 has tons torque. You can put Turbo cams in but their not ground the right way for N/A power they will produce power down low but nothing up top N/A cams are better as they are more even through the whole spectrum... from the factory there is no such thing as a 4g64t but many people are making them they put a 4g63t DOHC on the motor with some custom pistoms and they say it allows them way more tourque then a standard 4g63t goto
www.4g64.com for more info on this...
