It is currently Tue May 21, 2024 8:52 pm
 Post subject: 4g93 with 4g15 ecu?
PostPosted: Fri Sep 19, 2014 8:56 pm
I have a sedan with a 1.8 and im pretty sure it has a bad ecu. And i have a 95 coupe with a 1.5 and a bad bottom end bearing and im wondering if anybody knows if i can swap the 1.8 and run it off the 4g15 ecu/sensors. Im kind of doubting the 15 distributor will fit in the 93 cause the head is different. Googled many combinations of the words and didnt learn anything
