It is currently Thu Apr 25, 2024 3:30 am
PostPosted: Mon Aug 25, 2014 4:03 pm
I have a 92 colt that decided it did not want to live anymore. The problem is it's getting fuel but no spark. I happen to have a spare computer that works, at least it did a month ago when I tested it on said car and it still did not start. I have triple checked all of the connections on the car and they all seem fine. Even popped them off and re-seated them with no luck. I ran TMOLog while cranking and it shows the TDC sensor is working. I'm not really sure what else to check. Advise?
PostPosted: Wed Aug 27, 2014 7:30 am
I had an ECU go bad and lost all spark.
I used a multimeter to check the wiring to the ECU, internal resistances of my coils and circuits that relate to the coil and internal transistor design, and it all lead to a bad ECU.
FSM's located at www.lilevo.com/mirage/ will net you the diagnostic process.
Checking coil primary and secondary resistances, is a simple start.
Be aware that you irreparably flood the plugs if cranking too long with only fuel going in.
