It is currently Sat Apr 27, 2024 6:06 am
PostPosted: Sun Jul 07, 2013 11:37 pm
How do I put an aftermarket air intake on my 4g15 with that big bulky thing in my air filter which I believe is my 02 sensor but I am not sure help please?
1996 Honda civic lx
1994 Ford Ranger
1991 Dodge colt 4G15
PostPosted: Sun Jul 07, 2013 11:49 pm
o2 sensor is in the exhaust piping... you remove that big can (with the filter inside of it).. and connect a aftermarket filter to the hose.. might need a adapter or piece of pipe to make it work tho.
PostPosted: Sun Jul 07, 2013 11:50 pm
What sensor is that then or is it even a sensor... my car doesn't run without it so it does something....
1996 Honda civic lx
1994 Ford Ranger
PostPosted: Mon Jul 08, 2013 12:02 am
might be the mass airflow if that is the case (im not familiar with the 1.5 setups) then you can put a adapter plate on the maf and the filter will go onto it..
if it looks like this..
http://www.buyautoparts.com/autoparts/M ... Meter.html
then you would need something like this.. but for the 89-92 then just add a filter onto it..
http://www.ebay.com/itm/MAF-Mass-Air-Fl ... d4&vxp=mtr
PostPosted: Mon Jul 08, 2013 12:06 am
alright thank you
1996 Honda civic lx
1994 Ford Ranger
PostPosted: Wed Jul 10, 2013 3:32 pm
Playing devil's advocate here, you'll probably lose horsepower pulling the stock setup. It actually goes all the way to the fenderwell area to suck in cold air. The "cold air intakes" they sell are usually just a short piece of pipe with a crappy filter on it that will suck hot underhood air into the motor.
PostPosted: Thu Jul 11, 2013 2:05 pm
Yea im just leaving it the way it is thank you
1996 Honda civic lx
1994 Ford Ranger
PostPosted: Mon Jul 15, 2013 9:10 pm
You can put a K&N filter inside though.
PostPosted: Mon Jul 15, 2013 10:13 pm
Like just in replace of the other filter??
1996 Honda civic lx
1994 Ford Ranger
PostPosted: Fri Jul 19, 2013 1:09 am
Replace whatever cheap paper filter is in there with a K&N filter. It's the same filter the 1g dsm's use, part number E-2875.
PostPosted: Fri Jul 19, 2013 10:55 am
alright I will do that
1996 Honda civic lx
1994 Ford Ranger
PostPosted: Thu Sep 19, 2013 10:54 pm
If you're looking to block more engine heat from your intake, you could get an exhaust shop to bend you a piece of 3" stainless, roll some ceramic on it buy some silicone clamp bands (dont use rubber drainpipe ones trust me). Could cover the filter can in the ceramic as well.
Honestly, though, a 3* drop in air charge temp might prospectively give you a 1% boost in torque. That's less than 1 ft-lb of torque on a 4g15... If you coated the intake and exhaust as well you might get 3 or 4 in optimal conditions with tuning, and maybe squeeze 1 or 2 hp out.
If you can bake your own ceramic and have a friend at the muffler shop it might be worth it for you. If you have to pay full price, save up for an engine swap.
