It is currently Wed Oct 22, 2025 10:50 am
 Post subject: lightened flywheel
PostPosted: Tue Jun 11, 2013 7:49 am
do we have any lightened flywheel or a better upgrade for 4g15 engines? how many bolts do the 4g15 has?
 Post subject: Re: lightened flywheel
PostPosted: Tue Jun 11, 2013 6:59 pm
I want to say 5 bolt flywheel setup.
You can likely have a machine shop back cut the pressure plate a bit. The 4G15 is not made to rev high with the 3V heads, so a little reduction will probably net a slightly better shift up high, and sacrifice some idle and decel/low speed stability. Might not be all that noticeable, as the flywheel weight might only drop less than 1lb.
PostPosted: Wed Jun 12, 2013 5:11 am
how many tooth does the 4g15 flywheel has? would the datsun 5.5" flywheel similar?
