Radiator fan relay http://4g61t.org/forum/viewtopic.php?f=17&t=33170 |
Author: | coltster [ Sun Aug 08, 2010 4:48 pm ] |
Post subject: | Radiator fan relay |
I'm trying to figure out why my radiator fan does not come on at all and was wondering where the fuse and relay are located. Both of the boxes in the engine bay have the white typing all scratched off so I Don't know which fuse/relay goes to what. Is there anything else besides the fuse/relay that can make the radiator fan not work? What can I do to check if the fan motor is bad? Electrical has always been my weak point. Thanks! |
Author: | coltster [ Mon Aug 09, 2010 1:02 pm ] |
Post subject: | Re: Radiator fan relay |
Took a look at the fan motors and one of the fans (the small driver side fan motor) works. Tried to check the other fan (the big passenger side fan) but could not get it to come on by connecting it to the battery. As for the driver side fan, I checked the fuses and relays, neither of the 2 fuses (rad fan nor cond fan) were getting power and my question about that is are the fuses supposed to only get power once the radiator is on? or is it supposed to have power at all times? |
Author: | Colt_Driver91 [ Sun Jul 07, 2013 11:25 pm ] |
My radiator fan doesn't work either there is a fuse box when your looking at your engine bay on the left open that up there should be two black square relays and then a silver one with a round top that is your fan relay which is the reason mine doesn't work which I should get to getting here soon but if you run a wire from the side that has power to the positive connector on your fan it should turn on.. |
Author: | slowdsm [ Sun Jul 07, 2013 11:47 pm ] |
LOL post is almost 3 years old.. ![]() Steve |
Author: | Colt_Driver91 [ Sun Jul 07, 2013 11:49 pm ] |
Holy Damn didn't even see that well shit im talking to myself lol |
