| 4g61t.org http://4g61t.org/forum/ | |
| Oil Pressure Gauge http://4g61t.org/forum/viewtopic.php?f=17&t=33117 | Page 1 of 1 |
| Author: | coltster [ Sat Jul 31, 2010 11:36 am ] |
| Post subject: | Oil Pressure Gauge |
| Hey guys got another question here. I want to install an oil pressure gauge and was just wondering where the port is located to plug the oil pressure gauge into. Normally they are close to the oil filter but I have no idea where in this case. Has anyone done this mod yet and know where to find it? Thanks! | |
| Author: | Natedog [ Sat Jul 31, 2010 11:47 am ] |
| Post subject: | Re: Oil Pressure Gauge |
| http://www.roadraceengineering.com/inst ... nstall.htm This gives the info needed for running the turbo oil feed off the housing, you could use either port for the gauge. One is fresh filtered the other not. I use the filtered to the turbo on my mirage and the non to my gauge sender with no problems thus far. | |
| Author: | coltster [ Sat Jul 31, 2010 11:50 am ] |
| I'm trying to install the gauge in a 1.5L 4speed N/A. | |
| Author: | Natedog [ Sat Jul 31, 2010 11:52 am ] |
| Ahh, well I haven't done that... I'd agree with your first bet that there is a port near the oil filter. | |
| Author: | 89Mirageman [ Sat Jul 31, 2010 12:09 pm ] |
| I think the stock sensor for the light screws directly in the front of the engine block. I would either T off of that or just replace that sensor, with a gauge you really don't need the idiot light. | |
| Author: | coltster [ Sun Aug 01, 2010 10:48 am ] |
| Having no luck finding this sensor. Can't really see anything in front of the engine block, exhaust manifold is in the way. Is there like an online repair manual or something that I can use to find it? I'm out of ideas at this point : / | |
| Author: | 89Mirageman [ Sun Aug 01, 2010 12:26 pm ] |
| Seems like mine was just under the exhaust manifold on my 91 colt. It threads directly into the front of the engine block. Just look for wires going to a sensor on the block. | |
| Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ | |
