| 4g61t.org http://4g61t.org/forum/ | |
| Front wheel studs 92 Colt http://4g61t.org/forum/viewtopic.php?f=17&t=32982 | Page 1 of 1 |
| Author: | geobass [ Mon Jul 05, 2010 5:51 pm ] |
| Post subject: | Front wheel studs 92 Colt |
| I take it I can not fix broken ones in my driveway. The whole assembly must go to a shop? Thanks, George | |
| Author: | LILEVO [ Mon Jul 05, 2010 6:36 pm ] |
| Post subject: | Re: Front wheel studs 92 Colt |
| Or you can buy a 12 ton press for $100 and do it yourself! | |
| Author: | uweenukr [ Mon Jul 05, 2010 6:46 pm ] |
| Out of pure necessity and wasting alot time/energy you could try to use a vice or a big hammer. At the risk of breaking more parts it might be better to let a pro do it. | |
| Author: | Flying Eagle [ Mon Jul 05, 2010 8:40 pm ] |
| If the stud will clear behind the rotor, then yes a BFH will knock them out everytime. I do this everytime we mash the threads on one at work or when I have the luxury of one that was mashed and left for the next guy. If the stud will not clear, then yes you will have to remove the rotor/hub assembly for pressing. I can't remember if these captives have to be fully disassembled for stud removal or not. | |
| Author: | LILEVO [ Mon Jul 05, 2010 9:06 pm ] |
| Yeah they need to be pressed | |
| Author: | 89Mirageman [ Mon Jul 05, 2010 10:07 pm ] |
| I would just spend the money on a pair of expo knuckles. They are a direct swap and it gets rid of the captive rotor setup. You might be able to fix it with a slide hammer to separate the hubs while its still on the car but I can assure you it will be a PITA. | |
| Author: | geobass [ Wed Jul 07, 2010 7:23 pm ] |
| I took the knuckle to the friendly muffler shop. $15.00 out the door! I will have to look into the Expo knuckles. | |
| Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ | |
