dies out in wet or rain http://4g61t.org/forum/viewtopic.php?f=17&t=32245 |
Author: | dubcity47 [ Fri Apr 16, 2010 4:43 pm ] |
Post subject: | dies out in wet or rain |
got the 3g 4spd 8v 4g15 and the motor is still stock except a filter in a air line from the vaulve cover no ac or power steering but every time it rains or i hit a puddle the car retards and begins to die until couple hours later once it drys and it keeps me from getting to work on time when it does has anyone else had this problem if so please tell me how you solved it |
Author: | Evotistical [ Sat Apr 17, 2010 1:00 am ] |
Post subject: | Re: dies out in wet or rain |
sounds like a distributor issue. |
Author: | dubcity47 [ Sat Apr 17, 2010 9:37 am ] |
what can i do to prevent that |
Author: | Evotistical [ Sat Apr 17, 2010 11:16 am ] |
You probably need to talk apart your distributor, clean the contacts carefully with 1000 grit sand paper, and put the distributor back together with a new seal or very carefully with silicone rtv. |
Author: | dubcity47 [ Thu Apr 22, 2010 12:37 pm ] |
well it is not the ditrobutor it happened again and it just died out but it wont start know before that it sounded retarted bout 2-3 rpm |
Author: | jwcorn01 [ Tue May 11, 2010 4:57 pm ] |
I had the exact same problem. Changed the plug wires and never happened again. |
Author: | turboshawn [ Tue May 11, 2010 11:38 pm ] |
Quote: well it is not the ditrobutor it happened again and it just died out but it wont start know before that it sounded retarted bout 2-3 rpm
Please add in your location in your user control panel!!
Author: | turboshawn [ Tue May 11, 2010 11:40 pm ] |
Quote: I had the exact same problem. Changed the plug wires and never happened again.
+1 for jwcorn01) Yes check for cracks on the distrib cap and check the inner wires for rust. Then protect them the best you can.
Author: | rockit181 [ Thu Nov 11, 2010 8:49 am ] |
I had the same problem. Turns out it was the ECU |
