It is currently Tue Oct 21, 2025 6:37 pm
 Post subject: 4g15 head bolts
PostPosted: Tue Dec 21, 2010 7:22 pm
are the head bolts reusable that come in a 92 4g15? they have a hex style head and look like regular 1g dsm bolts.
i cannot find new one's at any auto parts store here in cincy.
thanks.
Red 90 talon AWD. evoIII, 20-25psi, 880cc, chip, maft, 272's.
Red 92 eagle summit 12v.
 Post subject: Re: 4g15 head bolts
PostPosted: Tue Dec 21, 2010 9:25 pm
If the manual says one final torque reading, then yes, but check for stretch anyways.
If the manuals says that they have a torque reading then a degree angle - they are torque to yield and should probably be changed.
www.lilevo.com/mirage/
PostPosted: Wed Dec 22, 2010 2:56 am
Thanks man. I searched the index and only could find a single torque spec. The spec was around 50 to 55 ft lbs. So that's what I put them too.
PostPosted: Sat Jan 01, 2011 6:12 pm
thanks.
you are not going to find them at a parts house only dealer and they aren't cheap.
91 plym colt 4g 4g15 12v/ 4g37 upgrades 5spd flat black
PostPosted: Mon Jan 03, 2011 11:44 pm
i found them at a NAPA like two years ago. didnt seem too hard to find. I think i had them the next day. dont remember the part number though.
PostPosted: Tue Jan 04, 2011 9:09 am
Here's a NAPA close to you:
NAPA AUTO PARTS
City Wide Auto Parts
4990 Montgomery Road
Cincinnati,OH 45212
(513) 242-1040
Cylinder Head Bolt part number is : FPG ES71206
Price is : $35.49 and comes with washers.
Hope this helps buddy!
AutoZone also has them...
Part # : ES71206
Price : $29.99
Closest one to you is:
3146 Reading
Cincinnati OH 45229
(513) 961-0700
PostPosted: Thu Jan 06, 2011 1:35 pm
the problem i ran across was the headbolts for 91-94 are different than 95 and up. and the cross referance was wrong, i try three different parts house and ran in to the same problem. the headbolts from the 95 and up are smaller in diamiter and shorter in lenght and have a 12 point head on it. thats what the parts houses were giving me. that is why i went to the dealer for the head bolt which i still have some where.
