It is currently Tue Oct 28, 2025 2:58 am
 Post subject: Spark Plugs
PostPosted: Mon Feb 01, 2010 10:21 pm
Which spark plugs whould you recommend in the stock 4g15? Which wires as well?
 Post subject: Re: Spark Plugs
PostPosted: Mon Feb 01, 2010 11:03 pm
New and cheap.
PostPosted: Mon Feb 01, 2010 11:55 pm
New and cheap.
Im doing a tune up on the whole engine.
I have always bought the cheapest parts for a tune up, just wondering if paying a lil more would show. Not looking for more HP. I just used of hearing "you get what you pay for" but on a basic tune-up?
PostPosted: Tue Feb 02, 2010 4:13 pm
Not on a 4g15. Four new champion plugs at walmart for $5 and a set of $25 wires and you're set.
PostPosted: Tue Feb 02, 2010 4:25 pm
NGK BPR5ES-11, shouldn't be more than $2 per plug at your local auto parts store.
PostPosted: Tue Feb 02, 2010 9:32 pm
Alright, i think im going to go with the basic.
PostPosted: Wed Feb 03, 2010 8:24 pm
i always put ngk's in, but go cheap on wires
91 plym colt 4g 4g15 12v/ 4g37 upgrades 5spd flat black
PostPosted: Wed Feb 03, 2010 9:13 pm
Got ya. Got my old job back, so i got the NGK plugs at work. Just got to get the wires.
"Im a marine tech by the way" :lol:
Money coming in again, so can finnaly put some money in the mirage. :supz:
PostPosted: Wed Feb 03, 2010 10:12 pm
:supz: good to hear
PostPosted: Sat Feb 13, 2010 10:05 pm
Ok well now i have ran into problems. I have a Chilton book i have been refering to. The book tells me fireing order in 1342, which you guys say that to. "i did researched" Heres the problem, the Chilton book says the firing order goes counter clockwise, but you guys say it goes clock wise. "Which is correct"? Well i thought i had everything hook up right, and tryed to start the car, it wouldnt start. After trying to turn over, a LOUD back fire! With a lil white smoke coming out the muffler. What am i doing wrong guys? Did i fruit and banana anything up? Car ran great before i change the plugs. Please help.
PostPosted: Sat Feb 13, 2010 11:49 pm
f'meng. there's four wires, could've just replaced them one by one and been good. or, you could try BOTH ways, one should work. there's only so many combinations. did you gap the plugs?
in cars, and especially mitsubishi's, a pioneering and persevering spirit will get you farther then a forum. try new things,try to think for yourself. for perspective, the finest members on an automotive forum are rarely heavy posters, because they're too busy in the garage and their hands are too dirty to use a keyboard :lol: you'll get it after awhille :wink:
PostPosted: Sun Feb 14, 2010 12:22 am
But im not going to make anything worse? By switch all this around?
I mean i could get out there and figure it out, i just dont want to mess anything else up in the process. The car is back fireing really loud. I dont know if it suppose to do that when the firing is wrong? If thats the case, i will get out there and start switching plugs and trying to turn it over.
Thanks man
PostPosted: Sun Feb 14, 2010 12:13 pm
Try it clockwise, doesn't work, try it counterclockwise. If neither way works, then you're probably doing something wrong.
PostPosted: Sun Feb 14, 2010 1:04 pm
I couldnt find #1 on the cap. But i looked closer, it was right there in my face. :lol: Its label 1 on the cap! So i went back and did as the book says, and it started right up!!!! :twisted:
Runs greats!!!
