| what is the size of 8 valve injector http://4g61t.org/forum/viewtopic.php?f=17&t=31629 |
| Author: | buddz [ Sat Jan 30, 2010 6:01 pm ] |
| Post subject: | what is the size of 8 valve injector |
may i know what is the size of 8 valve injector? if i use the 12V injector what are the pros and cons? thanks |
| Author: | 89Mirageman [ Sat Jan 30, 2010 6:22 pm ] |
| Post subject: | Re: what is the size of 8 valve injector |
I'm pretty sure the 8v and 12v injectors flow the same amount. |
| Author: | Mechacode [ Sat Jan 30, 2010 9:52 pm ] |
Yep.^ |
| Author: | buddz [ Sun Jan 31, 2010 11:19 am ] |
a ok..I thought the 8V injector is smaller than the 12V..It is 210CC? or what? thanks for replying |
| Author: | Mechacode [ Sun Jan 31, 2010 1:05 pm ] |
It wouldn't be smaller, it's for the same size engine (1.5l). I think the 4g15 injectors were 180cc and 4g37 injectors were 210cc? |
| Author: | buddz [ Sun Jan 31, 2010 7:23 pm ] |
a ok so if ever i'll use a 210cc injector it is possible to gain HP? |
| Author: | Mechacode [ Sun Jan 31, 2010 11:59 pm ] |
Maybe if you opened up both of the tubes on the bottom of the maf all the way and used the 210's they would work together to give a tiny bit more power. |
| Author: | Incoltnito [ Mon Feb 01, 2010 1:05 am ] |
Use a 1.8 liter 4g37 MAF if you use the 210cc injectors, or else it will be a waste. |
| Author: | Mechacode [ Mon Feb 01, 2010 4:07 pm ] |
He can't, he's an 8valve 4g15 and the wiring is different. |
| Author: | buddz [ Sat Feb 06, 2010 11:25 am ] |
Quote: He can't, he's an 8valve 4g15 and the wiring is different.
yes they said that it can't be...4G37 parts is for 4g15 12V upgrades
