It is currently Wed May 22, 2024 9:13 am
Post new topic  Reply to topic  [ 49 posts ]  Go to page Previous 1 2 3 4
 Post subject: Re: Your car's mileage
PostPosted: Thu Nov 29, 2012 7:25 pm
!991 base Plymouth Colt 4G15 12V (original) just tripped 321,000. Rebuilt the 4spd around 250,000 because it was popping out of gear (bearings going bad). Threw a timing belt because the crank bolt came loose around 280,000. Bent the Valves, so replaced the head with a freebie that was worse than the original head, but not too bad. Daily driver and gets between 45-47mpg on the highway. (feather on the pedal...) I LOVE this car!
PostPosted: Thu Nov 29, 2012 7:27 pm
PostPosted: Thu Nov 29, 2012 7:40 pm
315 000km on my 4G61T :).
PostPosted: Sat May 10, 2014 8:54 pm
91 stock eagle summit 4g15 12v 4 speed manual w 322k on dash which hasn't worked since i got the car. Smokes like its got 400k and tranny seal went out so it won't hold oil, still pretty good body tho except roof spots
94 Mitsubishi Mirage "4dr"
