Well, i found out the problem, first of all, related to compression test, the tester i had is small and does not rich the hole of spark 2 and 3, but i was able to measure the first and last ones and they where both the same, about 140, and the motor does not fail at all, and the VACUUM gauge does read correctly so i assume that there isn't any compression issue.
And regarding to water, no, in normal heat the motor does not loose any water, the reason i had to refill it with water was since the water was boling it was trowing it, but not in normal heat..
Anyway, i found out that the thermostat was broken, "it had a broken arm that caused the spring to fall off", basically i removed it in 3 pieces instead of one
hehehe i removed it, made a new gasket and leave it without the thermostat and the engine does not overheat anymore (seems to, i just did a small ride of 15 miles at ~90mph and it went fine).
So tomorrow im going to the dealer to buy a new one, anyway, my dad here which is helping me out told me that there is no need to hurry, and i can run without the thermostat, it will only make the engine get warm a little slower, but not big trouble, is that correct?
