It is currently Sun Nov 02, 2025 9:56 am
PostPosted: Fri Aug 27, 2010 9:33 pm
I had my ECU rebuilt at autoecu.com on ebay $50.00. I recieved it back and no spark ! did the tests in the manual to check for voltage from the ecu to the coil 6pin plug. no voltage. in fact its grounded so i unplug the ecu check the wire good not grounded. then i check pin 54 to the case of the ecu and its shorted. isnt pin 54 (yellow wire) supposed to carry voltage? is it supposed to have continuty to the ecu case? Im asking in case they give me a hard time. they claim a lifetime warranty.
PostPosted: Sun Aug 29, 2010 4:17 am
anyone???
PostPosted: Sun Aug 29, 2010 7:07 am
It sounds broken to me. That's the only wire that carries power to the PT.
