timing belt install http://4g61t.org/forum/viewtopic.php?f=17&t=1521 |
Author: | bo0oost [ Wed Dec 31, 1969 7:00 pm ] |
Post subject: | timing belt install |
Any help on installing a timing belt on 4g15? There don't seem to be any timing marks on the motor? THanks for your help! |
Author: | xlr8 [ Wed Dec 31, 1969 7:00 pm ] |
Post subject: | |
Does the 1.5L in your car come with the 8-valve head? If so then there is a mark on the right-hand side of the head (~3 oclock position) that must be lined up with the dot on the camshaft pulley and there is a protrusion just above the crankshaft pulley on the timing case (~1 oclock position) that must be lined up with the key on the sprocket. |
