It is currently Sat Apr 27, 2024 12:53 pm
 Post subject: timing belt install
Any help on installing a timing belt on 4g15?
There don't seem to be any timing marks on the motor?
THanks for your help!
'89 Colt 1.5L 5speed
'00 Z28 6speed
Does the 1.5L in your car come with the 8-valve head? If so then there is a mark on the right-hand side of the head (~3 oclock position) that must be lined up with the dot on the camshaft pulley and there is a protrusion just above the crankshaft pulley on the timing case (~1 oclock position) that must be lined up with the key on the sprocket.
