It is currently Tue May 07, 2024 2:14 am
 Post subject: Engine Swap
My son has a 91 Colt with the 1.5, 4 speed. He wants a bigger engine in the car. Since it would be easier for me to get involved in the beginning rather than the middle, I thought I would look for some help. What other engines fit in the car with a minimum of hassle. I don't want to change transmissions, radiators, etc if possible. Any ideas?
BANNED FOR FRAUD
Well, if you don't want to change anything else you'd probably be limited to only upgrading to the 1.8L. However, one you have the engine out replacing the other stuff is simple. For more ideas I'd goto:
http://apparts.netfirms.com
Jason Veraldi
Scammer
I thought it was possible to use the 2.0L engine with the original transmission? Just not the best route because of limited aftermarket clutch support.
If you can't use that combination, maybe look into importing one of the MIVEC engines to use.
With that said, read through this post and see if it's something you can handle. http://www.4g61t.com/forum/viewtopic.ph ... um=2&por=1 By far, the best route is to go with the 4g63 (2.0L) turbo engine.
 Post subject: .
yah you can definitely use the KM201 tranny, just dont expect it to last very long with 200+HP in front of it.
I'm selling a 4g61 (1.6turbo) w/ tranny.
http://www.4g61t.com/forum/viewtopic.php?p=7500#7500
Adam
93'FD Touring non-seq
05'WRX
