hyundai excel intake http://4g61t.org/forum/viewtopic.php?f=17&t=12050 |
Author: | VIPERGTS_3 [ Sat Dec 18, 2004 11:33 pm ] |
Post subject: | hyundai excel intake |
what is the difference if any in the internal design of the intake upper and lower on the hyundai and mitsubishi 4g15 ? |
Author: | X2T [ Sun Dec 19, 2004 11:48 am ] |
Post subject: | |
I think the early 8V is all the same 2 piece design. the 90+(?) 12V use a 1 piece manifold with oblong ports & since the distributor location changed the flange is different in that area. I just pulled mine off the other evening and I found it interesting how the PCV delivers to all 4 intake runners through little passageways cut into the flange at the upper/lower mating surface. but I digress... something I had been thinking of - the 1.8 SOHC uses a 2 piece manifold as well. the lower portion is totally different as the head ports are spaced differently, but the upper half looks the same but with the larger TB opening & bolt pattern. check out the plenum gasket for the 1.8L: ![]() that looks exactly the same as my Excel gasket including the extra hole for the EGR return port but minus the hole for the 8mm stud center-back. I'm thinking perhaps the 1.8 upper will bolt onto the Excel/CSM 8V lower & allow for mounting the larger 1.8 TB. there must be someone here who has seen both manifolds that can either confirm or deny this possibility. |
Author: | socrateez [ Sun Dec 19, 2004 12:32 pm ] |
Post subject: | |
Interesting idea! Let us know if it works, there are a lot of 8-valvers here who would die for a good mod! |
Author: | Berserko [ Sun Dec 19, 2004 2:22 pm ] |
Post subject: | |
hmm 90 Sonatas use a 2 peice intake mani. I wonder if you cpuld put the much more open sontat top on a 4g15 bottom... Something to try. |
Author: | X2T [ Sun Dec 19, 2004 2:58 pm ] |
Post subject: | |
I'm tempted to go to a parts store with my Excel gasket to try & compare directly with the 1.8, 2.0 or 2.4 single cam gaskets. the pic I posted is a Beck/Arnley plenum gasket. if anyone has access to a good listing of their stuff you can cross-reference #'s to the 2.0 & 2.4. aside from where I got the pic, I could not find anywhere else that listed the plenum gasket alone for the other apps. I have a similar upgrade for my Isuzu motor which gave me the idea a while back: http://www.4g61t.org/phpBB2/viewtopic.php?t=7910 after pulling my Excel apart the other day, I was pretty shocked to see just how tiny the TB opening really is. I have no real goals of making any power with this motor - it is what it is - but I welcome cheap scavenged upgrades and looking at that tiny thing rekindled the thought. checking car-part.com, an upper half & TB will run $50 or so + shipping. |
Author: | VIPERGTS_3 [ Sun Dec 19, 2004 7:47 pm ] |
Post subject: | |
THE SURGE TANK ON THE EXCEL IS RATHER LARGE HOWEVER THE TB PORT IS MICRO ITTY BITTY . I THINK I AM GOING TO TRY THIS JUST AS SOON AS THE GASKET COMPARISON IS MADE . I HAVE alot of these manifolds in my area did the eclipse have a baseline motor .... the 4g37 ? i may be mistaken but i have seen goodies on those i want |
Author: | HondaHunter [ Mon Dec 20, 2004 3:11 am ] |
Post subject: | |
Quote: Interesting idea! Let us know if it works, there are a lot of 8-valvers here who would die for a good mod!
![]() i hope this works....coz then im going junkyard hunting ![]() |
