It is currently Thu Oct 30, 2025 7:52 am
PostPosted: Sun Feb 07, 2010 5:38 pm
If you have fuel firing in, spark going off, and obviously air coming in from piston movement (engine cranking), you could have fouled plugs.
PostPosted: Mon Feb 08, 2010 7:03 pm
fouled plugs?....sorry im only 17 and this is my first car so im still in the learning stage :)
1991 Plymouth Colt - Project
PostPosted: Mon Feb 08, 2010 10:12 pm
sparkplugs.new ones are probably a good idea.
PostPosted: Sun Feb 14, 2010 7:46 pm
The plugs are good the previous owner replaced them right before I bought the car.
PostPosted: Mon Feb 15, 2010 9:20 am
It would not matter if they were good or not, if the engine flooded, the plugs will foul. That is the point we are trying to get across. How do you know the plugs are good now?
PostPosted: Thu Mar 11, 2010 8:33 pm
Ok guys I have an update........well unfortunally my engine is bad,I did a compression check after I timed it again and found out that I don't have any compression. The person I bought it from bought it from an older gentleman and he said that it needed a new timing belt, but didn't explain anything else that was wrong. So I find out that the belt slipped off when the car was running and bent the valves:( but lucky for me I'm buying back my first colt that I used as a parts car(after they took the front end off it) for close to nothing. by the way the motor is still good in it:). So hopefully I will be going to pick the car up tomorrow. Sorry for the novel just wanted to explain everything that's been going on.
