It is currently Tue Oct 21, 2025 7:28 am
PostPosted: Sun Aug 29, 2021 10:19 am
Does anybody happen to have a 4g15 flywheel around? I need to know its diameter. I do not need the clutch disc diameter. I need the the diameter including the teeth ring. Also the "thickness" of the flywheel.
PostPosted: Wed Feb 26, 2025 3:13 pm
Sorry no one had an answer for you. If you post at CSM Performance on FB, we can better help you.
