It is currently Mon Jun 03, 2024 8:09 pm
 Post subject: Running very slow (HELP)
PostPosted: Sat Mar 16, 2013 3:15 am
Okay, so it seems ever since I changed my timing belt and front crank seal, my car has been running slow.
On my way home from school a couple days ago, I started to drive up a road that wasn't very steep at all
and it took 19 seconds to get from 40 to 50mph. Yesterday coming home, another slight incline going 55mph,
I put the peddle all the way down going up it, and it was dropping in speed.
I don't think that the timing was off when putting it all back together, but I guess there is always a chance.
Do you guys think something could have happened during the last install? I don't know if I'm able to move
the distributor at all to change the timing if it is off just a little. Thanks again for your help guys.
PostPosted: Sat Mar 16, 2013 4:13 am
There is a difference between mechanical timing (timing belt) and ignition timing (distributor). Check your ignition timing with a timing light, check your cam timing by verifying all marks line up at TDC.
PostPosted: Sat Mar 16, 2013 3:25 pm
Sounds to me like you're retarded........one tooth! However one tooth either way should run, just not well. Had that happen plenty of times on the 1.5 during a belt job. Do what Nocturnal said and you should be fine I would think.
2012 Explorer Limited
1989 Colt GT clone 4G63t auto
1992 Talon TSi
1990 Talon TSi
1995 Crown Vic
1993 Ford F-250 BBF
1987 Chevy Sprint Turbo
