It is currently Tue Oct 21, 2025 4:33 pm
 Post subject: dist help on 4g15 12V
PostPosted: Fri Aug 14, 2009 7:14 am
Hello CSM junkie, I have a 1992 stock Colt 200e the 1.5 and I had change 2 distributor well used ones my question is when I check the main plug on the distributor there is power there, also there is power on the little bule one next to it but when I crank the car there is no power on the pink conector close to the distributor, what is this pink conector for ? does our car has cam sensor ? is the relay inside the distributor ? Please I need you help to find out if it is the distributor or not before I buy a new one. I can not get running, it does not start at all, and I check for spark and there is not getting any to the spark plug wires. is the pink one that drives the power to the dist.?
Please could you e mail me @ ibayter@gmail.com ? thanks a lot for your reply. I am desperate I need the car !
PostPosted: Thu Aug 20, 2009 8:32 pm
replace it.
PostPosted: Fri Dec 04, 2009 8:42 pm
I had the upper distributor shaft bearing go out under the pickup coil. As the bearing would overheat the car would quit running.
