Possible rear disc brake swap for 1st and 2nd gen models I need specs. http://4g61t.org/forum/viewtopic.php?f=16&t=41162 |
Author: | miragesist [ Fri Jan 26, 2018 10:36 pm ] |
Post subject: | Re: Possible rear disc brake swap for 1st and 2nd gen models I need specs. |
All mitsu rea calipers 89-94 will work you only will need the brackets and figure out how to install the cables for the hand brake into the calipers |
Author: | mitsubishikid [ Sun Feb 04, 2018 10:16 pm ] |
Major thanks to drcolt2000 for taking the time to get me the measurements from his sedan, According to drcolt2000, distance A is 80mm, from bolt centers, and distance B is 45mm again from bolt centers. will update if I ever find another 2nd gen local to me. |
