http://4g61t.org/forum/
85/85 throttle position switch
http://4g61t.org/forum/viewtopic.php?f=16&t=37709
Page 1 of 1
Author:  colt48188 [ Fri Apr 19, 2013 7:55 am ]
Post subject:  85/85 throttle position switch
Can anyone tell me if the 84 G32BT engine and the 85 G32BT engine both shared the same throttle position switch? through an exhaustive search I was only able to find a TPS for the Mitsu Mirage and was able to find none for the Colt turbo... As you know there was no Mirage here in the States in 84 for so I was wondering if I bit the bullet and spent the $150 for the 85 Mirage TPS would it work for my 84?
Can anyone help me with this?
Author:  colt48188 [ Tue Apr 30, 2013 11:50 am ]
Post subject:  Re: 85/85 throttle position switch
All,
I did some research here and found that the part number for the TPS for the 84 Turbo and the 85 Turbo are the same, MD614075. Then I did the research and found that the TPS carried by Rock Auto is listed to work with and 85 Mirage and is also a part number MD614075 so it will work for both cars.
https://www.phpbb.com/
