It is currently Sat Apr 27, 2024 6:30 pm
 Post subject: Adjust Idle
PostPosted: Sun Sep 26, 2010 3:27 pm
Anyone know how to adjust the idle on this car? Mine is idling a little too high.
Thank you!
________________
 Post subject: Re: Adjust Idle
PostPosted: Sun Sep 26, 2010 4:19 pm
if its a 4g15 or 4g63 there is usually a screw on the throttle body you can adjust. It is sometimes covered with a plastic cover. If you have issues finding it look online or in a manual (lilevo.com/mirage). Also maybe provide more information about the car.
something like:
PostPosted: Mon Sep 27, 2010 7:22 am
Sorry about that, I should have stated that my engine is a G32BT.
http://s118.photobucket.com/albums/o96/ ... ted/G32BT/
Thank you!
PostPosted: Mon Sep 27, 2010 8:50 am
If it was not idling high before and suddenly has started to I would look for a vacuum leak in one of the vacuum lines. Or take off the throttle body and clean the gunk that builds up off.
I unfortunately cannot actually answer your question. I have no idea how to adjust your idle. LOL
PostPosted: Tue Sep 28, 2010 7:55 am
Ok, I'll check the vacuum lines. Thank you!
**UPDATE**: Found a couple of bad vacuum lines. It idles perfect now!
__________________
PostPosted: Mon Nov 29, 2010 11:45 am
Have u got it yet? Search on here fo posts by me. Or go onto he starion/conquest forums. They have he same setup and same procedure.
