It is currently Sat Apr 27, 2024 5:18 pm
 Post subject: rods
PostPosted: Thu Apr 22, 2010 6:06 am
hi i would like to buy a set or rods and pistons
what are the best rods and pistons please?
i am hoping to buy the wiseco pistons and manley rods......are they good enough for 25psi boost?
regards
 Post subject: Re: rods
PostPosted: Thu Apr 22, 2010 10:04 am
regards
Didn't you already post this topic once before? I think we all told you that stock rods and pistons are fine.
PostPosted: Thu Apr 22, 2010 11:46 am
i have crack a piston :(
thats why i am asking now for new set of pistons and rods
PostPosted: Sun Apr 25, 2010 4:26 am
you would have to have everything custom made
PostPosted: Sun Apr 25, 2010 11:05 pm
why custom made?
PostPosted: Mon Apr 26, 2010 5:11 am
JE pistons makes pistons and i think manley or bill mitchell will make rods
PostPosted: Mon Apr 26, 2010 9:55 am
You posted this in the 1st and 2nd Gen section. Those cars use a G32B engine, not a 4G63. Nobody makes off-the-shelf engine parts for the G32B engine. What year is your car?
PostPosted: Thu May 06, 2010 7:28 pm
Its been about 4 years since I searched for and bought a set of turbo pistons for a G32T - they were in short supply then and expensive - I seem to remember paying $250 for the set of 4. The rods are the same rods as used in newer 4g37 motors - you should be able to match part numbers on various web sites to prove that out. YCP (Yang Chun Pistons) across the Pacific Ocean has G32T pistons in their catalog but generally don't keep them on the shelf - it takes a production run to cast and machine some economic order quantity before they'll build 'em. Again that was probably more like 6 years ago that I talked to them, David Chen was the guy's name with YCP.
Good luck on your search.
Phil Hutchinson
1986 G15B, 1986 G32B, 1988 G32B
