It is currently Sun Apr 28, 2024 1:13 pm
 Post subject: Head studs.....
PostPosted: Thu Feb 18, 2010 8:43 pm
Where can i buy a decent set of studs/bolts???
 Post subject: Re: Head studs.....
PostPosted: Sat Feb 20, 2010 10:33 pm
AM4.600-1LUB is the stud (they tell me you have to put it in upside down because of the thread pitch. the only thing you lose is the hex insert for removal)
300-8345 nut
200-8590 washer
all arp BTW
PostPosted: Mon Feb 22, 2010 1:17 am
Hey thanks again i'm learning everyday something new...
PostPosted: Thu May 19, 2011 2:15 pm
Where do you buy these items?
Thank you!
PostPosted: Thu May 19, 2011 2:25 pm
http://www.arp-bolts.com/
You will have to find a dealer or you could call Jegs and have them order the part numbers provided in a previous post.
PostPosted: Fri May 20, 2011 9:42 am
Is this AM4.600-1LUB the part number for the stud? I am having a hard time finding this stud. Please help!
Thank you,
________________
PostPosted: Fri May 20, 2011 10:16 am
I called Jegs. AM4.600-1LUB is indeed the part number and Jegs can order them in. They are $9.99 a piece. They also can order the nuts and washers. You total would be $159.60 before shipping/handling. 1-800-345-4545
PostPosted: Fri May 20, 2011 12:48 pm
Got it.
Thank you so much!!!!
__________________
PostPosted: Mon May 23, 2011 9:16 pm
just remember they go in upside down cause arp at the time did not have a stud that length that has the same pitch on both ends
