It is currently Sat Apr 27, 2024 2:06 pm
 Post subject: FUEL CUT!!!!
PostPosted: Thu Dec 17, 2009 11:42 am
Hi everyone, im from Peru,
I need help!! i have a c10, g32b: intercooler from 4agze, msd ignition,turbosmart boost controller, apexi safc neo, bigger fuel pump, etc.
Im having something like a fuel cut when i reach 12psi, at around 4rpm, i took borrow a hks fcd, but when i attemp to installing it, i didnt found the air pressure sensor......so im lost!!!
i run perfectly at 5psi, but when i try to get 6psi or more i feel the cut.
I dont know what else to do, does someone has the ecu map or something?
What im doing wrong?
 Post subject: Re: FUEL CUT!!!!
PostPosted: Thu Dec 17, 2009 12:15 pm
Are you using a wideband or egt sensor to monitor whats going on inside the engine? Have you pulled your spark plugs to see if the engine is running rich or lean?
PostPosted: Thu Dec 17, 2009 1:08 pm
I used an egt sensor, and yep, everything shows that the engine its running rich.
The ecu has a fuel cut? is it possbile to install the fcd?
the apexi has to do with the cut? maybe its wrong tuned or something.
i dont know what else can be
PostPosted: Thu Dec 17, 2009 8:25 pm
with a g32b you can go all the way to 14 psi before hit the fuel cut,,,, tuning problems georgio,,,<
PostPosted: Thu Dec 31, 2009 12:09 am
try disabling the distributor vacuum line. plug the vacuum line with a screw. sometimes this does the trick. you may have to turn down your distributor timing to not get any detonation at high psi though.
