more problems? http://4g61t.org/forum/viewtopic.php?f=16&t=30930 |
Author: | deco_will_fly [ Fri Oct 16, 2009 4:30 pm ] |
Post subject: | more problems? |
I guess this is what you deal with, any time you mod a car. So I don't know if its the year, the motor and tranny mounts, or even the tranny, but I have the motor in, everything is ready just trying to figure out a way to run my intake and exhaust. That stuff will happen this weekend however I have another new problem. The motor from my 86 sedan, mounted to the 4 speed that came in the 88 2nd gen hatch, sits clocked forword a few degrees. Well that translates to about 3 in. Now it did give me some room I could really use, howeve now the intake on my turbo lines right up with my fan. So my solution, reverse the fan and put it on the front, can I do that? Also if its just the tranny, when I get a new trannyis it going to clock back. I want to be driving on Sunday so the quicker I get this info the better. Thanks, Benjamin |
Author: | j2dapo [ Fri Oct 16, 2009 8:51 pm ] |
Post subject: | Re: more problems? |
Are you using the mounts from the original turbo motor? |
Author: | junk yard 86 colt [ Sat Oct 17, 2009 7:37 am ] |
im guessing not cause it only does that cause they changed the undermount on the 87/88 |
Author: | deco_will_fly [ Sun Oct 18, 2009 11:02 am ] |
Ya that's kinda the problem, the undermount was to long, I tryed using the tranny mount to see if it would clock back and it didn't, so untill I find a tranny I am kinda stuck using all the mounts off the non turbo motor, sucks a little but I just need to know if it will work, like I said, I kinda like the room in the back. And I will be getting a new rad at some point , after I actualy drive it for a bit. |
Author: | deco_will_fly [ Sun Oct 18, 2009 11:04 am ] |
And with that said, if any one has a spare 87 88 turbo trany laying around let me know, id love to get it. |
Author: | j2dapo [ Sun Oct 18, 2009 10:46 pm ] |
Just get a F5M22 or KM206 out of a talon or Galant, making sure its an early 90/91 donor. Also taking your axels with you to ensure they go into the tranny would be smart. |
