It is currently Sun Apr 28, 2024 12:42 am
 Post subject: Manual Tranny Fluid
PostPosted: Fri Apr 17, 2009 8:09 am
What are you guys using for the tranny? Thank you!
__________________
 Post subject: Re: Manual Tranny Fluid
PostPosted: Fri Apr 17, 2009 9:18 am
__________________
BG Synchroshift, GM synchromesh, Pennzoil Synchromesh, Redline MTL, Redline MT-90 <--- all of those work well.
PostPosted: Fri Apr 17, 2009 4:26 pm
__________________
I run the pennzoil myself because the local Autozone carries it and its in stock. I have tried all the others in the past and had good luck with them too.
PostPosted: Mon Apr 20, 2009 3:20 pm
I couldn't find any of the mentioned types so I got some Mobile synthetic 75w90 at Advanced on Sunday! Hope it is ok.
_____________
PostPosted: Mon Apr 20, 2009 3:43 pm
_____________
NO! Do NOT use that fluid. It will kill your synchros. It is not intended for transmissions, it is intended for rear differentials and stuff like that. Return that fluid and get normal 75w-90 GL-4 approved fluid if you can't find any of the other stuff we listed.
PostPosted: Mon Apr 20, 2009 3:49 pm
Oh crap! I'll get some of the right stuff and replace it tonight!!!! Thank you!
_______________
