It is currently Sat Apr 27, 2024 3:34 am
 Post subject: oil blow by
PostPosted: Mon Apr 06, 2009 10:33 pm
ok the car is running. it sounds good, i have a little bit of an exhaust leak, but all good i knew i needed a few gaskets. I am however having some big time oil blow by issues. it has more smoke coming out the back than i have ever seen. i dont think its the rings, but i will be doing a compresion test as soon as i can. i am thinking more along the lines of a valve seal problem. i have been told that the fact the motor didnt run for 15 years the seals will shrink up, and after running it a few times, they should seat right in and be all good. if any one has any other ideas bring them on, thanks every one.
 Post subject: Re: oil blow by
PostPosted: Tue Apr 07, 2009 6:01 pm
yea deffinetly put some time on the motor fix your exhaust leak. but yea just run it and see if it gets better. if not then it could be the valve seal or the turbo seal or the rings
PostPosted: Fri Apr 10, 2009 8:01 pm
ok, valve stem oil seals is where my problem is, unless the jet valves could some how be letting oil drane into the cylinder. if any one knows if that can happen please let me know. other wise, i need help. i just replaced the head gasket, and now i need to replace the valve seals, How do i do it with out removing the head. please some one there has got to be a way. a real way not some bull crap way like my backwords ass dad tried to tell me. thanks guys, if we can do this i can be driving withen the month. please please please.... oh and cheack my new post about the awd parts.....
PostPosted: Tue Apr 14, 2009 12:11 am
You could try the "pressure the cylinder with air" while you change the seals, which I think is sketchy. I would recommend the "stick rope in the cylinder" and then turn the engine until that piston is up, which should put enough pressure to change the seals without dropping the valve. Never tried it, but know lots of people who have done successfully.
