It is currently Thu May 23, 2024 12:07 am
 Post subject: g32bt timeing
PostPosted: Fri Dec 05, 2008 9:46 pm
ok, i seen some info regarding the 86 timeing vs the 87/88. something about tweeking it and seeing a big hp increas in the 86, when running a little higher boost. has any one played around with the timeing on this thing enough to add anything.
 Post subject: Re: g32bt timeing
PostPosted: Fri Dec 12, 2008 9:30 am
The timing on my car was off and I was getting the hickup problem, I set it to stock levels and it helped.
Make sure you car is in top shape maintenance wise before you try and play with the timing.
