It is currently Sun Apr 28, 2024 6:08 am
PostPosted: Wed Aug 13, 2008 2:29 pm
looking for as much info on these cars as possible.(engine code,swap info,tranny strength,etc) I have the chance to pick this up for 200$. It will run with starter fluid in the TB, think it needs a fuel pump. Thanks.
PostPosted: Wed Aug 13, 2008 5:43 pm
If you look at the black badge on the passenger side of the firewall you'll get some info.
engine code = g32b, 1.6L SOHC (non jet valve?) engine.
swap info = very unsure about that year but there's the possibilty of (mostly) bolting in a 4g63 with elantra mounts
tranny strength = likelihoods are of a 'weak' twin stick, whats the tranny code on that badge?
That car is cool and looks to have been sitting for a while. What's in the gas tank, a family of squirrels? Try good gas. Also the Throttle body on these cars don't like to sit and tend to leak coolant. Did you put the starting fluid through the fuel return line? Once you tried to start was there fuel coming out of that unconnected line?
Search the site there are a few 84 colt owners on here, hopefully they will comment. Lastly, with an unlimited amount of resources any swap is possible.
PostPosted: Wed Aug 13, 2008 7:58 pm
Sweet another new colt owner sides me :D
Should just leave it with the original engine and trans and do a few mods. A stock colt on 9psi is pretty fast as is.
Should off the stock exhaust and 2 cats then go 2.5". Even removing the 2nd cat made abit of a difference in mine.
Now If I could leave mine stock.......... :D
'84 dodge colt - Soon turbo header? mpi swap, 12b turbo 2.5" exhaust and ported head
'84 dodge omni GLH -red
'85 dodge omni GLHT silver- traded for colt
'85 GLHT spec horizon 13.8 @103 mph - now dead
'85 GLHT- blue
'86 GLH - blue
'86 GLHT- blue
and about 15 other dodges and misc junk
PostPosted: Fri Aug 15, 2008 4:59 pm
Thanks for the replys guys. Can anyone tell me the tranny code? Also, if I wanted to change it out with something more common, what would it be/how? Thanks again!
PostPosted: Fri Aug 15, 2008 7:05 pm
Good site but probably doesn't have the twin stick version listed.
http://www.drivetrain.com/transillamcmitsubishi.html
EDIT Here's the gold you are searching for:
http://www.txchange.com/km162.htm
PostPosted: Sat Sep 06, 2008 11:19 pm
Nice Car, $200 is a steal.
PostPosted: Mon Oct 27, 2008 8:36 pm
Pay the 200 and roll it like a rock star :supz:
