New member from central Florida http://4g61t.org/forum/viewtopic.php?f=101&t=40516 |
Page 1 of 2 |
Author: | BenderThe5G [ Wed Jan 27, 2016 4:01 pm ] |
Post subject: | New member from central Florida |
Hey guys, i'm new here recently referred to 4g61t by 89MirageMan. I currently own a 2000 Mirage LS coupe which imm slowly turning into a 4g64dohc power Asti rep and my 1997 Mirage DE sedan which i'll be converting to an Evo V replica with a turbo 4g64 dohc also. I'll be on the look out for an Expo soon for my delivery vehicle for my small company i made a couple years ago called TechNation. I'm a retailer over at mirageforums.net and hope to be able to bring parts for you guys here at 4g61t soon since csm's are getting a bit harder to find |
Author: | 89Mirageman [ Fri Jan 29, 2016 10:26 pm ] |
Post subject: | Re: New member from central Florida |
Not sure how I missed this but welcome. This guy is a fellow junkyard junkie. He actually came across a 3g summit hatch a little while ago and I asked him to join here. These cars are getting so scarce and we need the parts before they get crushed. If you can think of anything you need shoot him a pm. |
Author: | mirage760 [ Sat Jan 30, 2016 4:36 am ] |
Welcome. |
Author: | lancerman [ Sat Jan 30, 2016 9:33 am ] |
is there a dohc head that fits the 1.8 engines? though you might know |
Author: | BenderThe5G [ Sun Jan 31, 2016 1:22 am ] |
Thanks mirage760! Lancerman, the heads that fit the 4g93 are the 4g92 mivec dohc head, the dohc 4g93 head and the dohc 4g94 head |
Author: | 89Mirageman [ Sun Jan 31, 2016 11:06 am ] |
Bender, you can't just put a DOHC head on the SOHC 1.8 block though right? |
Author: | arrowhead [ Sun Jan 31, 2016 11:28 am ] |
HI, and welcome. Please let me know if you run across a valve cover with the -1600- casting on it. Thanks Mandy |
Author: | BenderThe5G [ Sun Jan 31, 2016 12:15 pm ] |
Chris, on the 5G you can although i wouldn't advise using a 2.0 head on a 1.8 block Arrowhead, i'll get to you as soon as i spot one |
Author: | Sunchaser [ Sun Jan 31, 2016 6:27 pm ] |
Welcome, I am also in central florida! |
Author: | 89Mirageman [ Mon Feb 01, 2016 9:30 am ] |
Quote: Chris, on the 5G you can although i wouldn't advise using a 2.0 head on a 1.8 block
I'm speaking about the 4G93 from the 5g Mirage and the expo wagons, not the 1.8 from the early elantra's. What engine are you talking about?
Author: | BenderThe5G [ Mon Feb 01, 2016 12:59 pm ] |
Thanks for the welcome sunchaser! Chris, 5g 4g93 is what i meant. You can swap in a 4g92 dohc head or one from the 4g93t dohc cm5a lancer gsr I havent read much into that swap since i'm planning on using a 64 with a kia head. Just gotta get a matching head gasket. Not sure if the dohc one changes from the sohc. I believe michael cadwell from mpf has a 4g93t head on his sohc 93 block 3g hatch and 1g dsm parts |
Author: | 89Mirageman [ Mon Feb 01, 2016 4:48 pm ] |
Awesome, had no idea. I will admit that I know very little about the engine from the 5g mirage. Too bad Hyundai never made an equivalent engine to steal the DOHC head from. |
Author: | BenderThe5G [ Mon Feb 01, 2016 6:05 pm ] |
Didnt Hyundai make a 1.6 dohc? If they did, it's most likely based off of the 4g92 or 4g18. If it's based off the 92, then we're in luck for a us side dohc swap |
Author: | UnderPSI [ Mon Feb 01, 2016 7:10 pm ] |
I've been intrigued with the growing number of mitsubishi v6 swaps in the 5th gen Mirages, from what I gather there really isn't much to it. |
